Dimension length of curve
Hello:
I would like to know if it is possible to dimension the length of a curve in AutoCad, for example, 1/4 of the circumference of a circle.
It is possible in other CAD programs, but I cannot seem to accomplish it in AutoCad.
Thank You
RE: Dimension length of curve
Try this (it's crude but it works).  Save it as a lsp file like "DimArc.lsp" then load it in AutoCad using the Tools menu or (Load"DimArc") on the command line, then run it by typing DimArc on the command line.
(DEFUN C:DimArc (/ p1 p2 p3 p4 om ang rad arc ark) ; Dimension an arc
 (SetVar "CMDECHO" 0)
 (Setq om (GetVar "OSMODE"))
 (setq p1 (getpoint "\nSnap to first point (must be on the arc also): ")
       p2 (getpoint "\nSnap to second point (does not have to be on the mark): ")
 (COMMAND "Osnap" "CEN")
 (setq p4 (getpoint "\nPick a point on the connecting arc: "))
 (COMMAND "Osnap" "NON")
 (setq p3 (getpoint "\nPoint to dimension location: ")
       ang ( - (angle p4 p1) (angle p4 p2))
       rad ( distance p4 p1)
       arc ( abs (* rad ang ))
       ark (rtos arc)
 (COMMAND "DIM1" "ANG" "" P4 P1 P2 P3 ARK P3)
 (COMMAND "DIM1" "HOM" "L" "")
 (COMMAND "DIM1" "TE" "L" PAUSE)
 (SetVar "OSMODE" om)
 (princ)
Thank you very much, it works great!
They should add it to AutoCad's dimension function.
