cutting through sheetmetal with an image
I am trying to use an image of say an animal to create a cut in sheetmetal.  Then, I want to export the dxf to a plasma cutter and cut the profile.  Any ideas of a good way to do this, and what formats to use?
RE: cutting through sheetmetal with an image
Try to save the animal image outline as a DXF, then import the section to ProE (in the sketcher mode of the feature).
Steve
http://www.sprdesign.com
