Portal Frame / Moment Frame Analysis
Help.
Is it adequate to provide bracing at roof level for moment frames and portal frames to limit defleflection on minor axis of the columns/stachion?
What is the prctically of having moment resisting pad bases, as a slid uplif on the pad means that the pressure on the foundation is affected?
RE: Portal Frame / Moment Frame Analysis
Try the Moment Frame and Shear Wall forum
corus
