Modeling cables
Modeling cables
Hi
Does anyone know how to model wires in SW2004.
The cables has to look bent as it will be looking
physically.
physically.
RE: Modeling cables
RE: Modeling cables
I thought the Routing add-in was going to take this up eventually, but I'm not sure about that. It's only hear say, so don't quote me on that.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
RE: Modeling cables
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
RE: Modeling cables
When using 3Dsketch - push the tab key to control the direction - X,Y - X,Z - Y,Z - Etc... You can also just drop those lines Horzontal, Vertical or in space. You can also use Splines in 3Dsketch as well.
Scott Baugh, CSWP
FAQ731-376
RE: Modeling cables
The spline is an excellent idea, please note that starting in SolidWorks 2004 you can "fit a spline" between 2 or more lines. This is very helpful in modelling cable connections.
Cheers,
Joseph
RE: Modeling cables
RE: Modeling cables
SW tells me that the new tube routing functions will be supporting cables very soon if not already (including connectivity).
Be naughty - save Santa a trip.
RE: Modeling cables
RE: Modeling cables
Mr. Pickles
RE: Modeling cables
When are you going to arrive at the Conference?
I'll be there on Saturday afternoon through Tuesday morning (flight in the morning).
I'm there for the VAR Conference... to bad they don't have both going on at the same time...
Oh well maybe I'll see you there... maybe
Scott Baugh, CSWP
FAQ731-376
RE: Modeling cables
I get there Sat afternoon as well. Leaving Wed AM. I will be working in the Partner Pavillian sometimes, and attending a few round tables and such. I may even be sneaking into a particular VAR session...
Mr. Pickles
RE: Modeling cables
I was - and he did. So at least I didn't get coal.....
OK, OK, It's a reference to my holiday sig. "Be naughty - Save Santa a trip..."
