Over pressure in piping
A volume of liquid trapped in an enclosed piping system has the potential to expand with a corresponding rise in ambient temperature, How can I relieve that over pressure in LPG and gasoline pipings? Is a relieve valve the better solution?
RE: Over pressure in piping
In Canada, little, liquid thermal relieve valves are mandatory on LPG piping between each pair of isolation points (block valves, positive displacement pumps, check valves, etc.). If this is an outdoor installation, piping the thermal relieve valves to a safe location is not required (usually these thermal relief valves are little, 1/4" units).
For liquids which do not vaporize when the pressure is reduced out the thermal relief valves (gasoline, kerosene, etc.), the design of the thermal relieve valves is more of a traditional safety valve and these are piped to a safe location.
All blocked in sections of piping which contain an expansible fluid, must be protected against overpressure.
anyway, our systems are usually designed so that a) every positive displacement pump had either an internal relief, or, depending upon the use and location, a relief back to the supply, etc. (supply usually open to tank); b) every section of pipe that could be physically isolated usually had a relief valve around the isolation valve or a relief back to the tank, etc; and c) we established valving procedures (which valves were open, which valves were closed) under all conceived operating conditions to account for thermal expansion
for our fuel oil, relief to atmoshere (to the ground) was not an option -- I would assume that in the USA, consideration for fugitive emissions might have some bearing on how relief valves are piped (but, I plead ignorance here)...
