API for Flipping Mate Alignment
Can someone help me create a macro/program to flip the mate alignment? The following are the main lines of the code that I have started to use from a recorded macro. The first line seems to work every time for selecting the mate if it is preselected. The next line for picking the mate entity is the problem. I can not figure out how to make it pick the correct surface. When I get it to pick the correct entities, the command swModel.EditMate2 works. Or is there a better approach? I am using SW2004. Thank you.
boolstatus = swModel.Extension.SelectByID(swFeat.Name, "MATE", 0, 0, 0, False, 0, Nothing)
boolstatus = swModel.Extension.SelectByID("", swMate.MateEntity(1).ReferenceType, swMate.MateEntity(1).EntityParams(0), swMate.MateEntity(1).EntityParams(1), swMate.MateEntity(1).EntityParams(2), True, 1, Nothing)
'Change alignment indicator
If swMate.alignment = 1 Then
NewAlign = 0
Else
NewAlign = 1
End If
swModel.EditMate2 swMate.Type, NewAlign, swMate.CanBeFlipped, 0.01, 0, 0, 1, 1, 0.5235987755983, 0.5235987755983, 0.5235987755983, longstatus
NewAlign = 0
Else
NewAlign = 1
End If
RE: API for Flipping Mate Alignment
•When a macro records selections, it does not do so in a manner that is easily adapted to a generic case. The macro recorder is basically just recording your mouse click location and the subsequent action.
•Learn how the Selection Manager works. This is how you can access objects that are preselected when a macro starts.
•When digging through the Selection Manager's selections, it is sometimes necessary to do a little more manipulation to get the object you really want. For instance, you may need to get a component or body when you have a face or edge selected. In your case, you might want the mate entities once you have the mate. Try Mate::GetMateEntities.
•You can make selections during macro run time if you use forms. Set the form ShowModal property to False and you can interact with SolidWorks while the macro is running.
More to come when I get a chance to look at more recent version of SW.
http://www.EsoxRepublic.com
Thank you,
Look up SelectionMgr in the SW API Help, you should find some examples there as well.
Ken
You can get the entities from the mate using Mate::GetMateEntities.
Could you access the mate entities with Mate2.MateEntity, get the info you need from them, and then select them with the selection manager?
Option Explicit
Public Enum swMateType_e
swMateCOINCIDENT = 0
swMateCONCENTRIC = 1
swMatePERPENDICULAR = 2
swMatePARALLEL = 3
swMateTANGENT = 4
swMateDISTANCE = 5
swMateANGLE = 6
swMateUNKNOWN = 7
swMateSYMMETRIC = 8
swMateCAMFOLLOWER = 9
swMateGEAR = 10
End Enum
Public Enum swMateAlign_e
swMateAlignALIGNED = 0
swMateAlignANTI_ALIGNED = 1
swMateAlignCLOSEST = 2
End Enum
Public Enum swMateEntity2ReferenceType_e
swMateEntity2ReferenceType_Point = 0
swMateEntity2ReferenceType_Line = 1
swMateEntity2ReferenceType_Circle = 2
swMateEntity2ReferenceType_Plane = 3
swMateEntity2ReferenceType_Cylinder = 4
swMateEntity2ReferenceType_Sphere = 5
swMateEntity2ReferenceType_Set = 6
swMateEntity2ReferenceType_Cone = 7
swMateEntity2ReferenceType_SweptSurface = 8
swMateEntity2ReferenceType_MultipleSurface = 9
swMateEntity2ReferenceType_GenSurface = 10
swMateEntity2ReferenceType_Ellipse = 11
swMateEntity2ReferenceType_GeneralCurve = 12
swMateEntity2ReferenceType_UNKNOWN = 13
End Enum
Public Enum swAddMateError_e
swAddMateError_ErrorUknown = 0
swAddMateError_NoError = 1
swAddMateError_IncorrectMateType = 2
swAddMateError_IncorrectAlignment = 3
swAddMateError_IncorrectSelections = 4
swAddMateError_OverDefinedAssembly = 5
End Enum
Function SelectMateEntity _
( _
swApp As SldWorks.SldWorks, _
swModel As SldWorks.ModelDoc2, _
swMateEnt As SldWorks.MateEntity2, _
nMark As Long _
) As Boolean
Dim swEnt As SldWorks.entity
Dim swSelMgr As SldWorks.SelectionMgr
Dim swSelData As SldWorks.SelectData
Dim bRet As Boolean
Select Case swMateEnt.ReferenceType
Case swMateEntity2ReferenceType_Point, _
swMateEntity2ReferenceType_Line, _
swMateEntity2ReferenceType_Circle, _
swMateEntity2ReferenceType_Plane, _
swMateEntity2ReferenceType_Cylinder, _
swMateEntity2ReferenceType_Sphere, _
swMateEntity2ReferenceType_Cone, _
Set swSelMgr = swModel.SelectionManager
Set swSelData = swSelMgr.CreateSelectData
Set swEnt = swMateEnt.reference: Debug.Assert Not swEnt Is Nothing
swSelData.mark = nMark
bRet = swEnt.Select4(True, swSelData): Debug.Assert bRet
SelectMateEntity = bRet
Exit Function
Case swMateEntity2ReferenceType_Set, _
swMateEntity2ReferenceType_MultipleSurface, _
swMateEntity2ReferenceType_GenSurface, _
swMateEntity2ReferenceType_Ellipse, _
swMateEntity2ReferenceType_GeneralCurve, _
Debug.Assert False
Case Else
Debug.Assert False
End Select
SelectMateEntity = False
End Function
Sub main()
Dim swApp As SldWorks.SldWorks
Dim swModel As SldWorks.ModelDoc2
Dim swAssy As SldWorks.AssemblyDoc
Dim swFeat As SldWorks.feature
Dim swMate As SldWorks.Mate2
Dim swDispDim As SldWorks.DisplayDimension
Dim swDim As SldWorks.Dimension
Dim sVarType As String
Dim nVarFactor As Double
Dim nMateDist As Double
Dim nNumMateEnt As Long
Dim swMateEnt() As SldWorks.MateEntity2
Dim vMateEntPar As Variant
Dim swComp As SldWorks.Component2
Dim nNewMateAlign As Long
Dim nRetVal As Long
Dim i As Long
Dim bRet As Boolean
Set swApp = Application.SldWorks
Set swModel = swApp.ActiveDoc
Set swAssy = swModel
Set swFeat = swSelMgr.GetSelectedObject5(1)
Set swMate = swFeat.GetSpecificFeature2
Set swDispDim = swMate.DisplayDimension
Debug.Print "File = " & swModel.GetPathName
Debug.Print " " & swFeat.Name
Debug.Print " Type = " & swMate.Type
Debug.Print " Alignment = " & swMate.alignment
Debug.Print " CanBeFlipped = " & swMate.CanBeFlipped
Select Case swMate.Type
Case swMateANGLE
sVarType = " deg"
nVarFactor = 57.3
Case swMateDISTANCE
sVarType = " mm"
nVarFactor = 1000#
Case swMateGEAR
sVarType = " ratio"
nVarFactor = 1#
End Select
If swMateANGLE = swMate.Type Or swMateDISTANCE = swMate.Type Then
Debug.Print " MaxVar = " & swMate.MaximumVariation * nVarFactor & sVarType
Debug.Print " MinVar = " & swMate.MinimumVariation * nVarFactor & sVarType
End If
If Not swDispDim Is Nothing Then
Set swDim = swDispDim.GetDimension
nMateDist = swDim.GetSystemValue2("")
' broken:
' SPR 200810 - "Mate2::DisplayDimension returns incorrect value for a swMateGEAR mate if first ratio is not unity"
Debug.Print " Dim Value = " & nMateDist * nVarFactor & sVarType
End If
nNumMateEnt = swMate.GetMateEntityCount
ReDim swMateEnt(nNumMateEnt)
For i = 0 To nNumMateEnt - 1
Set swMateEnt(i) = swMate.MateEntity(i)
Set swComp = swMateEnt(i).ReferenceComponent
vMateEntPar = swMateEnt(i).EntityParams
Debug.Print " RefType(" & i & ") = " & swMateEnt(i).ReferenceType
Debug.Print " Component = " & swComp.Name2 & " (" & swComp.ReferencedConfiguration & ") --> " & swComp.GetPathName
Debug.Print " Point = (" & vMateEntPar(0) * 1000# & ", " & vMateEntPar(1) * 1000# & ", " & vMateEntPar(2) * 1000# & ") mm"
Debug.Print " Vector = (" & vMateEntPar(3) & ", " & vMateEntPar(4) & ", " & vMateEntPar(5) & ")"
Debug.Print " Radius 1 = " & vMateEntPar(6) * 1000# & " mm"
Debug.Print " Radius 2 = " & vMateEntPar(7) * 1000# & " mm"
Next i
' cannot change alignment on these mate types
Case swMateGEAR
Exit Sub
End Select
If swMateAlignALIGNED = swMate.alignment Then
nNewMateAlign = swMateAlignANTI_ALIGNED
Else
If swMateAlignANTI_ALIGNED = swMate.alignment Then
nNewMateAlign = swMateAlignALIGNED
Else
' closest alignment, so changing alignment does not make sense
Debug.Assert swMateAlignCLOSEST = swMate.alignment
Exit Sub
End If
End If
swModel.ClearSelection2 True
bRet = SelectMateEntity(swApp, swModel, swMateEnt(i), 1): Debug.Assert bRet
Next i
' AssemblyDoc::EditMate2 requires mate feature to be last selected object
bRet = swFeat.Select2(True, 0): Debug.Assert bRet
' broken:
' SPR 200809 - "AssemblyDoc::EditMate2 returns swAddMateError_ErrorUknown when successful"
swAssy.EditMate2 _
swMate.Type, _
nNewMateAlign, _
True, _
nMateDist, _
swMate.MaximumVariation, _
swMate.MinimumVariation, _
0#, _
0#, _
nMateDist, _
swMate.MinimumVariation, nRetVal
' do not assert since may overdefine assy or other error
'Debug.Assert swAddMateError_NoError = nRetVal
' do not assert since assy may have rebuild errors due to changing mate alignment
bRet = swModel.EditRebuild3
'Debug.Assert bRet
End Sub
