Gas seal for wastewater?
I have more than once seen pumps damaged when, for whatever reason, the seal water system fails at a wastewater facility. I am curious about the viability of nitrogen gas pump seals in that environment. Since such a system can send an alarm well before the nitrogen supply actually runs out, it would seem to solve this problem. But invariably I see water seal systems.
Does anyone have experience with gas seals in this application?
JKM9
RE: Gas seal for wastewater?
I'm spec'ing one out now for a vertical sump pump.  Sure.  There may be some issues depending upon the application.
Remember that if the N2 source is a bottle that you can have the same situation arise- the bottle pressure drops below the pressure needed for the seal, and oops....
