Heat Exchanger Tube Fouling versus Pressure Drop
I am trying to use flow versus pressure drop through heat exchanger tubes to determine equipment condition. The original flow versus pressure drop data obtained through testing in 1995 matched the calculated data for the heat exchanger. However, the pressure drop in the heat exchanger is currently greater than expected. The current data was obtained in a heat exchanger that was cleaned 3 months ago. Is there any information that correlates tube fouling and pressure drop versus flow through heat exchanger tubes.
RE: Heat Exchanger Tube Fouling versus Pressure Drop
