High pressure adhesive/sealant recommendations
I have an application where I need to bond two small 7075 Aluminum housings together (permanently); the bonded assembly must withstand ~2500 psi and ~300 degrees F with no pressure bleed-though into the small interior cavity.
Any suggestions on how best to accomplish this?
Mike
Mike
RE: High pressure adhesive/sealant recommendations
-Mike
