"opaque" viewports in 3D
hi,
I have a 3D drawing that has viewports in paper space with hideplot on, and paper space view set to "hidden" so the wireframe is invisible as i work in paper space. I'm finding that if I make an MTEXT annotation (or dimension, for that matter) that, if I drag it over the viewport it becomes "invisible" in paper space. It's still there, and shows when plotting, but otherwise I can't see it to place it, etc. Also, I notice that the viewport appears "opaque" in that if I place it over objects in paper space, e.g. the title block, etc. they are hidden. It's as if the viewport is on a higher "z" level, stacked on top of other objects in paper space.
Can anyone offer guidance to control this?
thanks,
sundemon
thanks,
sundemon
RE: "opaque" viewports in 3D
Regards - Richard
FYI, I am in parallel projection, so the problem isn't limited to that projection. Also, I previously worked using 2000 and remeber a similar situation.
sundemon
