ISO Tolerances
ISO Tolerances
ISO Tolerances
Where can I find a complete listing of the ISO shaft and bore tolerance designations (such as H7, p9, etc)?
RE: ISO Tolerances
There are many catalogs which have these ISO tol.
Begin with INA bearings, Stockdrive, all bearing companies.
The mechanical handbook has the tolerances.
Happy hunting.
RE: ISO Tolerances
The ISO standard number is 286. This ISO standard has also been adopted by Australian standards as AS1654.1 and AS1654.2 which can be purchased online at www.standards.com.au
RE: ISO Tolerances
Try going to http://www.kok.com/
We are currently using this program on each of our engineers computers. It's a great program.
RE: ISO Tolerances
I need ISO shaft and bore tolerance designations (such as H7, p9, etc)?
RE: ISO Tolerances
You can find part of the answer in Machineries Handbook
for the H7 portion, I have an old Handbook and it does
not list the p9 tolerances. I do have a standard at work
and would be glad to fax it to you.  I believe it is a
din standard.  The capital letters apply to the bores
and the small letters apply to the shaft.
email j.geisey@juno.com
RE: ISO Tolerances
ISO standard 2768-mk what does the the mk stand for
