Using Bonus Menus from AutoCAD R14 in version 2000i
Does anyone know how to use the bonus menu toolbars from release 14 in release 2000i? I have become very attached to the bonus toolbars & I want them to transfer to release 2000i.
RE: Using Bonus Menus from AutoCAD R14 in version 2000i
if everyone helps everybody the world will be a better place
Anyone who has Acad14 may zip the bonus directory and send you. About 2.42 mb, when zipped 689 kb.
Only you have to load the menu file
ac_bonus.mnl
and run
(load "ac_bonus.lsp")
After that, it works with Acad2000 etc. just as it did under Acad14
I dunno if you know how to load it, but here is how:
type Menuload,push browse and search for the map express in the root of your Acad 2000 map. There is a file acetmain.mns if there is not but only an acetmain.mnu than you have to change the filetype in the below of THAT screen. Now you select the acetmain.mns file and push ok. After this you get back in the screen, push load and whala back you have your wanted files, now with rightclock on a toolbar you can select the ones you want to be visible, but you probably know that :)
Good Luck.
THANKS A BUNCH!
Pity I don't get a star though!
