Changing weldment properties
I am very new to SW and am trying to draw a part that uses .75 x .75 x .125 steel square tube. I do not see it listed and would like to add it to the list. What is the best and/or easiest way to do this? Thanks!
Brett
Brett
RE: Changing weldment properties
The path would be something like this - C:\Program Files\SolidWorks04\data\weldment profiles\ansi inch\square tube
You can make a new folder if you need too under "Weldment Profiles"
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
