RAS and ndiswan.sys
RAS and ndiswan.sys
I am trying without avail to connect my server and I can dial out using phone dialer and hyperterminal, but when I use dial-up networking (which i need to connect the workstations i am not mistaken) i get an error message saying the Remote Access Service Manager cannot start because a file (ndiswan.sys) could not be opened. I have tried reinstalling the server CD as well as copying another user's file over the top of my ndiswan.sys file to see if it was corrupted by any chance. Can anyone help me out there??
Thanks in advance!!
Thanks in advance!!
RE: RAS and ndiswan.sys
I have the same problem with Windows 2000 SP2. Have you resolved the issue and if so How? Any help will be appreciated? Do you know what caused this problem with Dial-up Networking?
Michael Schneier
Any ideas/solutions are appreciated.
John
jtrudeau@talisman-energy.com
http://www.eventid.net/display.asp?eventid=20027&source=
Hope this helps
I am sorry to say that the cure at EVENTID does not help. The best thing to do, I found was to re-format and then re-install Windows 2000 from my Recovery CD and then go to Windows Update to get all the updates and then re-install all my programs. Dial-up Networking is NOT a separate program as it is in Windows 98 where one can uninstall and reinstall it.
My problem with the Dial-up started after I did a Disaster Recovery using Vertias' Backup Exec ver. 4.6. Stomp says their new software from Veritas fixes the problem. Never tested this fact out!
Michael Schneier
