ceramic extrusion for exterior application
I am researching ceramic extrusions for use on a bulding facade. The specification is 45mm outside dia. x 1500mm length, pale gray colour, slightly textured finish. I understand that rollers used in certain kilns, eg. Reidhammer, fit this description. Does anyone know of ceramic manufacturers making such items and whether they will degrade under a freeze/thaw cycle?
RE: ceramic extrusion for exterior application
www.azom.com/suppliers.asp?supplierID=360
They will also be able to advise you on the freeze thaw issue.
