effect on pump operates at differnt viscosity
Gents,
If the centrifugal pump operates at different fluid , hence viscosity is different, does the head remains the same assuming no change to the system dynamics or resistance , thus the seystem curve remains the same too??? i know for a lighter fluid the discharge pressure reduces at the pump flange (static energy) however the head should remain the same??? i am really confused pls assisset
upm
upm
RE: effect on pump operates at differnt viscosity
1.The brake horsepower requirement will increase.
2.You will notice a reduction in the head the pump will produce.
3.Some reduction in capacity will occur with moderate and high viscosities.
4.The pump's efficiency will decrease.
High viscosity fluids are better handled with positive displacement pumps that are affected differently than centrifugal pumps by a change in fluid viscosity:
At a constant speed, changes in viscosity will have very little affect on capacity.
The total head will probably increase with viscosity because of higher system resistance.
The brake horsepower (kilowatts) will increase with capacity.
The efficiency probably will not be affected because of less leakage through the internal pump clearances. In some cases the efficiency will incease.
International College
Naresuan University
Phitsanulok
Thailand
any one can assist in field pump evaluation in such case assuming the speed/system resistance remains constant
upm
Head is always the same regardless of the specific gravity.
I therefore avoid pressure in the calculations because my puny brain gets confused and then I add that to the puny brains in my fellow workers and we have the 3 stooges going on, and I am Moe by nature so I end up hitting people all the time and going to jail.
Sooo,
I make the conversion to pressuure as needed to deal with people in the field. I work in head all the way, make the simple conversion to pressure to answer specific questions, discuss field problems, etc.
PUMPDESIGNER
Centrifugal pumps, irrespective of the pumped fluid, develop same head and power drawn by a pump mainly depends upon the mass flow rate of fluid moved through it(and head is generally used in the power equation rather than pressure). Power increases with increase in density and this is taken care in the power equation by the term specific weight.
Work done by the pump increases and subsequently you should increase the power input also. If you don't have sufficient capacity prime mover, it may overload and your system will be destroyed.
BHp = H*Q*SG/(3960*eff)
H - head, ft
Q - flow, gpm
SG - specific gravity
eff - pump efficiency
For a constant flow, a centrifugal pump always puts out a constant head. Therefore, as the SG increases, the BHp requirement is directionally proportional to the change in SG.
Although the discharge pressure will change for a changing SG, the head doesn't for a constant flow.
Viscosity, as previously discussed, lowers the head and flow from a pump and increases the BHp requirement. Lots of pump handbooks will have the method for adjusting the pump curve and BHp requirements for a high visc fluid.
upm
You are a funny guy, and correct of course about the power relationship to flow.
PUMPDESIGNER
