DEFAULT YELLOW TEXT
DEFAULT YELLOW TEXT
DEFAULT YELLOW TEXT
HI EVERYBODY,
IS THERE ANY POSSIBILITY THAT I CAN CHANGE THE DEFAULT TEXT COLOR BEFORE START DIMENSIONING? ALSO IN REFERENCE DIMENSION?
THANKS IN ADVANCE
JOYRIC
RE: DEFAULT YELLOW TEXT
In Proe2001 if you want to change the dims in part mode and drawing mode it is under View > System Colors > Letter click on the sample box (should show yellow) and adjust.
Mark Megarity
http://www.txsdesign.com/
