Converting a sealed bearing
I have been asked to convert the belt pulley bearings on a diesel engine (alternator belt) so that they may be lubricated as part of a preventative maintenance program. Even though the current bearings are sealed, the mindset is that if we grease them on a regular basis, they will last much longer.
It has been suggested that I add a grease zerk to the front dust cover, remove the front bearing seal and reverse the back seal to allow grease to flow out.
I have a few questions for the forum:
Does this idea sound like one worth pursuing?
Would reversing the bearing seal on the back of the bearing really allow grease to ooze out when the mechanic lubes the bearing?
If it does work, will adding too much grease cause the bearing to overheat?
Do I need to be concerned about mixing new grease with the original lubricant?
Did any other red flags go up when you read this post?
Sincerely,
Andrew Murphy
Sincerely,
Andrew Murphy
RE: Converting a sealed bearing
Depends on how long you want the grease to last. You can typically get 5-10000 hrs. If you have not had any failures I would think twice before changing anything. I take it that this is someone elses design and you are just modifying it ?
Probably not fast enough. Of course, it depends on how fast the guy injects it. And many bearing seals are not designed to be reversed so it might not even be possible (depends on bearing). There are also shields, which do have a small gap, but even these would probably not allow the grease to be evacuated fast enough. I think you would have to rely on having plenty of space on the grease nipple side, which of course depends on the design of the dust cover. Suggest you check with the bearing manufacturer.
Yes. Bearings typically cannot take grease volume exceeding more than about 1/4 to 1/3 of the internal free space. And after you have greased a bearing, it needs to be run at fairly low speed for a while to allow the grease to "channel", otherwise you will get gross overheating. The best bet is to grease during rotation.
In some cases, yes. Some high performance greases do not mix well with other types and can produce a ghastly black mess. Again, you would have to check with the specific bearing manufacturer.
Is it correct to assume other basic causal factors like alignment, belt tightness etc have been checked and eliminated as the problem, because providing more grease than is neccessary in these circumstances will not provide a "fix".
However, if the engine is operating in an environment that contains abrasive dust/corrosive materials and it is impractical to effectively prevent their ingress with seals then new grease, preferably continuously or at frequent intervals will be a big help as a regular out-flow of clean grease will prevent abrasive grit entering the bearing.
design engineer specified the
correct sealing arrangement for
this bearing. Too much lube is
not good and often you cannot
mix greases. The grease must be
compatable with the seal material.
If you are having early failures,
I would guess you are tensioning
these too tight.
Suggestion : Try a different pulley ( what condition is the Vee of the pulley? If the belts are being over tightened is there room for a pulley that has another Vee? ) and if you have room try a double row ball bearing to take up the load.
Have you thought about running the bearing in oil bath instead of grease ? The oil reservoir could be vented, and the oil drained and replaced without any of the pressure buildup problems. Fitting additional external oil seals to an open bearing might be more easily said than done though.
If the seals wear out, letting contamination in, then re-greasing has something to offer. But so would inquiring about alternate seal materials.
If the bearings rum nuch over 120F, or the grease is dry or caked, then ordering bearings with fancier synthetic grease might double or triple life. without the hassle/danger of re-greasing. In my experience It is often possible to remove seals in-damaged with a dull penknife, which then allows flushing out the new/old grease (don't used chlorinted solvents), and re-lube with Kluber something or other.
If the failure looks like overload, then, like others have said, the belt tension may simply need to be controlled better.
The original post doesn't say who made the engine, but if its all OE spec from a 'reputable' manufacturer, my general suggestion is dont touch it. My reason.....
Alternator pulley brgs are generally rotating outer ring applications and this gives the grease a hard time because it is never able to escape the rotational cf. Generally greases under cf wont 'channel' easily and tend to loose base oil. To withstand this unusual operating condition, tensioner pulley brg greases are normally uniquely developed for the application. Apart from the obvious incompatibility issue, its quite likely that an 'off the shelf' grease (that would have to be used for relubrication) wont work very well in the high cf environment and give unpredictably short life.
Yes, automotive bits and pieces are built to a cost, but the are also quite well developed in many subtle ways. In attempting a redesign a system such as a pulley tensioner you could spend a lot of time 'reinventing the wheel' ! Generally engine accessories are made and tested to last the life of the engine, (although of course there is always the occasional early casualty due to manufacturing process variations !). If you therefore envisage running the engine well beyond a normal life span, and/or cannot tolerate any un-planned failures of the tensioner system, I would suggest that a more sensible form of preventative maintenance may be to replace the whole tensioner pulley at say 50% normal life expectancy. Doing things this way will mean no design work, no development time, no unexpected problems, in short no buggeration. Just a two hour task using established procedures once every 6 years or so.
...and if its not a rotating outer-ring brg application just ignore paragraph 3 but my conclusion will be the same !
Gerry.
I understand everything presented here. I plan to approach my team leaders with some alternative suggestions. However, I would like to provide some additional documentation in my report other than simply citing this forum. Although I will give credit where credit is due.
Can anyone point me in the direction of published reports or a good source for reports that support any of the concerns brought up here? If you can at least point me the right direction, I'll be happy to hunt them down.
I am still haunted by my engineering professors who would not accept any citation from the internet. ;o)
Sincerely,
Andrew Murphy
http://www.bardenbearings.com/PDF%20CD/MACHINET.PDF
The hard-to-get SKF General catalog has re-lube intervals too, and are based on normal grease.
Bearing failure analysis -
http://www.bardenbearings.com/scan%20pdf/Bearing%20Fail...
FAG has a real nice multi page one. I think it may be on their website but registration is required.
** I think NSK do publish some quaterly Technical Journals in which they sometimes discuss their latest developments. Of course these are not really the 'latest' developments, but if you can get hold of some of these publications it may be of help to you. They may even be available on the net.
You should get a detailed drawing of your bearing and seal configuration from the manufacturer. It is likely if you reverse the seals that you will eliminate excess grease from escaping the bearing and at the same time 'vent' in contaminants - I don't think this is what you are trying to accomplish.
