Convert from 2004 back to 2003
One component of a large assembly was converted to SW2004 sp01. I need to get it back to 2003 sp3.1 rather than recreate from scratch. Is there any way to do this?
RE: Convert from 2004 back to 2003
Not and maintain parametric features.
Parasolid Export or STEP will give uou a dumb solid that 2003 can open.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
You cannot backwards migrate into a earlier version of solidworks while keeping the feature tree.
You're best bet is to export it as a Parasolid (or whichever translation you choose) though 2003, after you import the file, run it through featureworks to regain as much of the sketches & features back. (if you got the addin)
There are a few things you can try, to recover the older version. Check in the solidworks backup directory of the user that opened the file up, Solidworks make a backup of a file when you open it.
The other thing to try is talk to you administator and see if there is a backup file of the data that you could have them restore for you. At my place we can go back for one year and get old data files.
Just some thoughts that may help.
Thanks, I tried the export to parasolid, then featureworks, but not much success due to threads, etc not recognized. At least I have the solid for the assembly.
Monkeywrench
Like you, and probably many others, I learned the hard way that you should always, always, always make backups of your part & assembly models.... especially before upgrading to a newer version of SW. Actually the same goes for any program files.
CorBlimeyLimey
Barrie, Ontario
FAQ559-863
Thanks for the responses. I looked on my Win2000 C: drive and found a SW Backups folder that was empty. Woops, I thought I wasn't making any backups for some reason, or I had recently cleaned them all out; but that wasn't the case: another folder under Documents and Settings/ myname/ Local Settings/ TempSWBackupDirectory/ and there I found the backup file I needed. It pays to look around and know what the backup system is actually doing. Happy New Year! 12/31/03
You can setup a specific backup folder in your tools\options\System options\Backups - From there you can make a permenant folder that will store all your SW backups only. ***Also this is special to note***. Where is says make a backup every "X" amount of changes. That doens't mean everytime you add a sketch line or change something, that it will make a backup. That means after "X" amount of Rebuilds, you will get a backup made.
To add to CorBlimeyLimey response you should also and ALWAYS, ALWAYS test the new version before converting to the newest version. I have seen many people eat the carpeting to keep from screaming, because they wish they wouldn't have switched because it caused this or that problem... So always test it before switching over fully. You can run more than 2 different versions of SW on one station. you just have to install into different folders. I usually use Solidworks03, or Solidworks04, etc...
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
It is an aggrivation I have with Solidworks as well.  This is especially true if you do contract design work for other people who have different versions.
As a marketing tool - I think the Solidworks people have shot the bull on this one.
All that it is is aggrevating.
Spurs
At the risk of sounding offensive ….what do you find aggravating? Are you referring to the original thread comment about the backwards incompatibility of SolidWorks? If you are and you know of a 3D solids mechanical design program which can do what SW does, is as easy to learn as SW, has the tech support that SW and it’s VAR’s offer, for the same or less than the price that SW sells for AND has backwards compatibility, then please, PLEASE, share your knowledge. There are many people who subscribe to ENG-TIPS forums who would love to find the perfect design tool.
You state that SW has “shot the bull on this one”. In my opinion, they have found the Bullseye and are zeroing-in on dead centre faster than any of the so-called competition.
On a more positive note, it has been stated in this and other threads, that you can install different versions of SW on one computer, which would allow the use of whichever version a particular client needs. I realise that newer is not always better, but an alternative would be to convince your clients that they should update their software to take advantage of the latest offerings (which you and your other clients have done) and thereby remain competitive.
You could use eDrawings (the viewer is free to download) if your clients need to view & mark up drawings or PDF files (if you have the conversion module) or simple hardcopies for manufacture if that’s all that is needed.
Sorry to rant on my but this forum is meant for SW users to find answers to problems they have, or to share tips & tricks they have found. It is not for negative comments or bitching sessions. If anyone wants to complain about SolidWorks then do it where it counts….directly to SolidWorks. Doing it here just provokes responses like this which go on & on & on & on & on & on & on & on & on & on & on &………………………
CorBlimeyLimey
Barrie, Ontario
FAQ559-863
CorBlimeyLimey
Yes - the backwards compatibility is aggrevating.
I am not provoking anything accept hopefully some future improvment in this regard.
I have told SW of this aggrevation over 2 years ago.  Hopefully by seeing it here again, there will be a meaningful resolution.  So take that in a positive spirit with which it is intended.
Heck - Im even willing to spend extra money on a backwards conversion utility if thats what it takes!
Backwards compatibility will probably never happen. This has been discussed to death in this forum and others for YEARS. You can keep asking but I don't think we will ever see this happen. Unless some 3rd party programmer or company comes in and makes it happen.
Scott Baugh, CSWP
FAQ731-376
SW is hardly the only software package to have this issue.
A lack of backwards compatibility is not a bug, it is a feature.
Crashj
Backwards compatibility is not truly possible when novel and innovative features are used in a contemporary version of a part file.  How could I represent a full radius in SW 2001 that I created in SW 2004?  It cannot happen.  This isn't MS Word, where text can be displayed with or without fancy techniques used in more advanced versions.  The part is either true to the design or it isn't.  Older versions simply cannot replicate the advances of contemporary versions.  So we may not like it, but there are no solutions except the use of dumb solids or equivalent.
Since I run a business, backing up all files is mandatory--especially before doing something risky like jumping into a new version of SolidWorks or even a new version of the part/assembly.  Doing this and knowing what version my client needs before performing the work eliminates backward compatibility problems altogether.  (Prevention is better than cure.)
Jeff Mowry
Industrial Designhaus, LLC
http://www.industrialdesignhaus.com
Unlike cor blimey, I will make no apologies so my comments.  Please listen to CorBlimey, Scott B and most important to Theophilus.
It IS NOT POSSIBLE to provide backward compatibility with any complex software that continues (THANK GOODNESS) to be enhanced and provide new features.  Even to attempt to do so would require a massive software programming effort.  Then you have to do all combinations of all software versions otherwise some whiner would bleat because they left out SW2003 SP4 to SW2001 SP10 or some such wierd combination.  The approximations and lost data that would result even if they they were partially succesful would just frustrate you even more - then you would realy be complaining.
As a business decision it is also a no-brainer, because the percentage of total users who would actually use this is SO small.
I for one do not want any sane business to be rat-holing prescious software resources into this kind of dead end unfunctionallity. Gimme new stuff!!!
Be naughty - save Santa a trip.
Hey There,
I don't think the group of users who would like to have a converter for 2004-2-2003 would be too small. I work with 2004 but my supliers still work with 2003 and they don't intend to go to 2004. So now we are having trouble with the feedback.
Kind Regards,
Bouke Brouwers.
This is the most difficult circumstance and I run into it all the time--especially in Asia.
However, in my case, we do all the design and really don't need parametric editing ability with our vendors--if they can read it, that's good enough.
So we export assemblies into parasolids, which will open in whatever version of SW and maintain the relative positions of each part in the assembly well enough to get the point across.  Annotations and feedback can be done with E-Drawings.
Ideally, you find out what version your suppliers (or clients, etc.) need before you take off on the project.  It's always handy to keep a few older versions of SW on your system for those reasons--or for viewing/editing files that need to remain in older versions.  We have this come up frequently as well.
Jeff Mowry
What is the current count? Must be 300,000 seats by now.  I doubt seriously if more than 1.5% of them will want to use backrev conversion.  (Except for the one off time when they goof and load the new rev in production before they should have - and then its probably only 2%).  That is not an ecconomically viable situation for software development budgets regardless of the fact (as previous pointed out by several people) that it is virually impossible to achieve. Heck, you can't even backrev some MS Office products for the same reasons!!!! There is no equivalent for the newer features.  And even if you could do it you can bet your life that 99% of the 1.5% will still bitch that it ain't perfect or the way they personally wanted it. Then they will also bitch (along with the other 98.5% of users) that there weren't enough enhancements in the new rev.........
It's flogging a dead horse.
I was - and he did. So at least I didn't get coal.....
I have MS Office 2003 Word, Excel and PowerPoint files, that are just fine when opened in MS Office 2000.
What up with that? Them bums get something right?
Mr. Pickles
Because Word and Excel don't really add much in the way of "new" features, just interface enhancements.
3D modeling software is a lot more complex.
Personally, I would not mind the option to save back, but I believe the programming effort involved would be too great and would take away from putting in more useful functions.
Can anyone else think of a 3d cad program that allows saving back.
Jason Capriotti
ThyssenKrupp Elevator
Mr. Pickles is right in that the lateset Office products don't do too bad a job (depends on what fancy features you use) but for the reason Gildashard states.  But back in '97 type vintage, there were some real issues.  However, all things considered I think MS does not do a bad job.
Thanks for the steady voice of reason, Gildashard.  We are all getting a bit punchy on this one.  I do, believe it or not, agree that personally I would not mind the option to save back.  Very occasionally it could make life a little easier, but it is not going to happen so I'm not holding my breath.
The only thing you can really do is Parasolid out and back in.  Now they are talking about getting some sort of feature compatibility in STEP, so maybe we could eventually get a partial solution.  A "solid body feature"
might allow for some of the incompatibilities?  Dunno about cuts though.  Anyone ever done a save as part on an assembly containing some imported Parasolids? - might give an idea of what it would look like.
OK, OK, It's a reference to my holiday sig. "Be naughty - Save Santa a trip..."
JNR
I think your 1.5% figure on those who wish to backsave is out to lunch.
The problem is not when you keep the information inside your own company.  The problem is when you have to transmit data to the outside world who usually run different versions of the software.
In Autocad for example, when you backsave, you may loose some functionality, but usually 90% + is there and you can work with the information.
If solidworks would allow you to backsave and give 75% functionality, I dont think that we would have such a heated discussion. I dont buy the notion that no one wants it or no one would use it, or that its too difficult.  On a backsaving issue, I wouldnt expect perfection, just something thats usable.
I don't want to get everyone's hopes up, those that are wanting backward compatibility. But I read this in Comp.cad.solidworks Newsgroup a few days ago and thought I would post this in here.
Hi Guys,
visit us in booth #17 in Boston for the following demos:
ShapeWorks - nurb surfacing inside SolidWorks
ExChangeWorks - saves SW files from newer versions to older with design tree
3D File Converter - saves SW files into 3DS Max, Lightwave and *.obj
Picture Converter - converts *.bmp pictures into SW sketch
See you there,
Baren-Boym Company
www.Baren-Boym.com
I'll be going to the Conference this weekend and I will be checking this out!
Scott Baugh, CSWP
FAQ731-376
Most new functionality encourages upgrades. Backwards compatibility functionality does not do so. A cynical perspective is that SW wants to encourage more upgrades.
1.  Like I said in my last post, backsave might be nice at times, but what I meant by my 1.5% was those who "must have"  - those who would be planning on using it routinely.
2.  Your point on customers or vendors having older revs. is valid (and I have encountered it). But again, if you are really needing SW feature functionality after you export to them, then it is important enough that they ought to be up to the latest rev.  In our business I would have a hard time dealing with companies that don't pay for the support licence.  (Of course if you are the one who is out of date, well....).
3.  As it turns out we have found that except under exceptional circumstances it is safer to send a Parasolid anyway.  We have had some (even large) companies make very expensive mistakes by someone either using the wrong configuration or inadvertently suppressing a feature or something. You would think that was a no-brainer, but noooooo......  One of them was having a large and complex investment casting wax mold made and fortunately the machine shop happened also to be one that knows our parts very well. They figured out that the model they had been sent by the casting house was basically the machined configuration!!! We got lucky that time.  Could have been a $100,000 mistake for them and a leadtime disaster for us.
4.  If this 3rd party stuff does work the way we hope (IF) then the most we should expect is getting it as a Partner solution.  I don't think SW would adopt it.   Probably the time required to check it all out on new revs. would delay the new revs.  (Of course there are always SP's....) As a 3rd party they can get away with some lag in their options as long as the basic software (in this case surfacing) works on time.  Come to think of it, I believe we have a seat of it on one of our systems, which means we have a support licence for upgrades.  Hey, guys, maybe I will be able to let you know if it really works?  Ahh, look at me - getting all excited about something I didn't think much of yesterday!  Never let it be said that I'm closed minded...
With regard to the presence of 2 different versions of SW on a system, I tried that recently and it didn't work.  I wanted to check SW2004 to see if its worthwhile upgrading the lot of us.  So I installed it into a seperate partion on my HD.  Yes, I could run SW2004 fine, but could I run our old version...of course not.  So I had to take it off again (both versions that is) re-install 2001 to be able to work again.
Just my 2p on running 2 versions on the same machine...
"Gimme dat stickwelder, will yer lad.  No need to get all fancy wid'those modern drills." Apprenticeship Lesson 61
TreeHuggingApserger,
I have both 2004 and 2003 running on my machine as I'm responding to this.  I'm assuming that the error you got said something like "Solidworks Journal Files already Exist".  If that was the error you have to go into Tools, Options, System Options.  Then in file locations make sure the directory name for the journal files that SW creates are different for each version of SW.
mncad
This may sound stupid, but I see it often...
One you have to install each version in it own directory. EX: Solidworks01+, Solidworks03, Solidworks04...
If you run each of them at the same time you might get that error that mncad posted.
If your saving a parasolid from SW04 and try to open it in SW03 make sure you save the Parasolid to version 14. Same goes for SW03 - Version 13 - Always save it one verion back of the recent Parasolid version for and older version of SW to open it.
I run SW04, SW03 and SW01+ and I can run all 3 together at one time. So I know running them together and loading them onto one machine does work.
Scott Baugh, CSWP
FAQ731-376
THIS IS EXACTLY WHY WE WON'T UPGRADE AND PAY THE HIGH PRICE OF MAINTENANCE FOR THE 2004 VERSION. THE NEW BENEFITS DON'T OFFSET THE RIDICULUS COST OF TRYING TO RE-ACQUIRE A 'CORRUPTED' PART OR ASSEMBLY WHEN WORKING THRU VARIOUS VERSIONS OF SOLIDWORKS.
If everyone out there who has had to even consider this thread, would call their retailer and /or solidworks direct and complain then you'd see the programmers develop solidworks just like autocad. You don't see autocad preventing backward compatible issues from slowing down sales do you. We run 2001+ and won't upgrade for just the reasons presented here.
I urge everyone to complain. "The squeeky wheel gets the grease!"
db
AES PRODUCTS INC.
CHICO, CALIFORNIA
Hmm, I wouldn't put it that strong! Yes, i'm sure nobody would disagree that a save option to save your part back to 2003 would be very handy but I don't think anyone is really spending much time in the problem. Using version 2004 in respect 2001plus saves me a lot of time. More time then it costs me to now and then save a file as a parasolid...
2001+ will never be able to figure out a multiple-body part without some sort of alteration of the 2001+ code (and many other more advanced features that are part of improving through upgrades).  This is a feature that simply cannot be backward compatible, whereas color-coded layers in ACAD can simply be ignored in previous releases or defaulted to a single color (or some other less drastic backward change).
The magnitude of code change necessary to maintain solid bodies and their parametric features is tremendous when compared with the code changes necessary in displaying arcs and lines in three-view format.
Jeff Mowry
Theophilus - the voice of calm and reason yet again!  He is right.  AUTOCRUD and most older generation CAD systems are completely different in concept from modern solid modellers.  As such you don't just make "stuff" on "layers" that YOUR brain has to make something real out of and so on  - the logic is not the same.
Now don't go and take this all personal, but the mere fact that you don't seem to understand this and the real technical problem in general suggests that maybe you ought not be be using this type of CAD system?  Maybe the old stuff of more the kind of thing you need?
BTW:  I only said "AUTOCRUD" just to stir all of you up, so don't take umbrage - just a joke.  It is a fine system for many purposes, just as virtually all CAD systems are.  They all have their stengths and weaknesses.
No need to yell their cdennyb!
AutoCAD is preventing users from bring in older files to their new versions of AutoCAD. At least SW lets you bring in old files to newer versions. (This is what I have been told by my customers and other people. I can't test this because I don't have AutoCAD here... Why would I want it... I have SW!!!)
Anyhow I'm back from the Conference and I checked out what I posted above.
Not what you might think. It's a neat concept but that's about it. When I asked about the program they informed me that it was still in experimentation mode, which was fine.
1) First thing he did was he open a part.
2) The part was a small cylinder extruded. With a square extrusion off of it. The Edges had round corners. At the end of the square Extrusion there was wavy surface. That Surface cut the Square extrusion.
3) First thing he did was remove the surface and the cut feature.
4) He saved the file as a 3dx file format.
5) Close the file.
6) Reopen it in SW04
That tells me nothing about how SW03 or older versions will interrupt the file.
7) SW04 rebuilt the file... like using a macro to make the part... simple.
I asked if Dimensions from the sketches could be transferred.
8) He tried it again... No dice! The dimensions are removed.
I asked how does this program handle new functions in later versions of SW for older versions?
9) His response... They are import features.
Just like saving out a Parasolid.
So to my conclusion. This functionality and this program as it is now is useless.
1) Because a new function is brought in as an imported feature. Yes you get some of the features it will recognize. But you could get the same thing if you used Feature Works, and it would leave the rest as an imported feature.
2) It doesn't save Dimensions that are required for editing of the sketches. Then the sketches become under defined and can be moved by accident.
3) I didn't see him try and open it in SW03 or older version. So how can I tell what the response would be?
4) If you did export out this info then the face ID's are different. What are you going to do when you do this with and assembly? You will lose mates if you used faces...
These are some things to think about when saving to different versions.
If I think of more I'll post them!
Scott Baugh, CSWP
FAQ731-376
It is true that importing files into older versions of Solidworks would have trouble with new features.  However, many of the parts we all create do not use new features, they are simply a collection of extrudes, revolves and fillets.  Perhaps a "save as" that would save as a SW2001+ or SW2003 file would help out with a great majority of the problems we have with vendors who have not upgraded yet.
It was also written above, "In our business I would have a hard time dealing with companies that don't pay for the support license."  Is dealing with Asia, I don't always have the luxury of switching vendors.  Pricing, capabilities, and a good working relationship seem like good enough reasons to look past the error of not paying for a support license.
Perhaps it would but it's not going to happen. You have 3 choices here:
1) Deal with the fact that you will not be able to save back a version, because you cna't do it from SW natively.
2) Install all ther versions you need to install onto your HDD. Then work on the Version that your client is using. (You would have install each SW into a new directory - e.g. Solidworks01+, Solidworks03, Solidworks04, etc...)
3) Look at the baren-boym add-in. www.barenboym.com
YOu might only use extrudes, fillets, and revolves... but what about your customers? is that all they ever use? If so then you should look into Item3.
Scott Baugh, CSWP
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
