How to fill surface object.
Hello.
For example, I made a vase with surface procedure(not solid protrusion).
When I want to fill it up, how can I do that?
Thanks for reading...
RE: How to fill surface object.
Do you mean add material thickness or beer?
In Proe 2001 one way is to Insert>Protrusion>Use Quilt...
In Wild.... Edit>Thicken
1. create the surfaces
2. Make sure the surfaces you've created completely enclose a space (you can't have any openings)
3. Create a surface merge feature. You may have to do this two surfaces at a time until you have a surface merge of the entire set of surfaces.
4. Then edit>solidify in Wildfire and you have a solid protrusion.
From that point on, you can edit dimensions, add cuts or other protrusions, or whatever.
