oil deaeration
oil deaeration
Does anyone have any suggestions for effectively removing the air from engine oil in a dry sump oiling system? I have tried dry sump tanks from many aftermarket manufacturers and none of them are very good at removing the air from the oil. Most of them splash the oil from the sump over one or more perforated plates. Any help would be appreciated.
RE: oil deaeration
The more gently the oil swirls around and down the tank, the more air will escape.
The position and design of the pick up also helps to reduce picking up aereated oil.
Adequate, but not excessive oil flow also helps, as does a good scraper system to reduce windage inside the engine.
Also look to keep oil returning from the overhead gear and valvtrain from impacting the crank, by scavanging it from the rocker box or by directing it to the sump by a path that is clear of moveing parts.
pat
RE: oil deaeration
RE: oil deaeration
Have you tried sucking out the air from the oil tank. The idea is to create some 'vacuum' above the swirl pot. This will minimize the air near the swirl pot from further 'enriching' the oil with air.
At the same time, it is crucial to minimize oil vapor or splashes from being sucked out as well. If the sucked out vapor or splashes is too much, you may need to return the oil back to the oil tank through catch tank or other devices.
It is also helpful to find the right oil for your application. We have tried different oil over the same engine application and we learned that oil specification, additives, life, etc. really influence the oil aeration.
Much like what Pat has mentioned, oil scrapper is really helpful in minimizing oil aeration and to decrease pumping losses.
RE: oil deaeration
RE: oil deaeration
Keep the wheels on the ground
Bob
showshine@aol.com
RE: oil deaeration
RE: oil deaeration
I have been hooked on this mag since, well, a long time, because Smokey was their tech guy. I like the pictures!
Rod
RE: oil deaeration
great book if you like fabricating stuff, or if you don't still has a lot of info on dry sump oil tanks.
RE: oil deaeration
Just my .02
RE: oil deaeration
What inspired you to try that? Or was it serendipity? ;)
Kevin
RE: oil deaeration
Rod
RE: oil deaeration
We decided to run smaller hoses on one of our small block Chevy dyno mules just to see what kind of results we could get. We had been in the process of studying windage. We ran clear -8AN, -10AN, & -12AN lines with an oil pan that had a Lexan window in it and video taped the results.
RE: oil deaeration
Now that would be an interesting video to see. I have a spare Suzuki G10 engine (993cc -- tiny) that I am thinking of mounting on a platform that I can tilt side to side and fore and aft. In addition to the pan, I was also considering sectioning out several areas on the side of the block to be able to see in there as well (no dyno loading -- just windage studies).
Did you mount an internal light or was external illumination sufficient? Another interesting idea might be to add a fluorescent tracer and use UV illumination. Not sure if a standard video camera would be able to pick that up under low ambient light conditions, though. Be wild to watch directly in any event.
Just to make sure I am interpreting correctly, you are speaking only of the scavenge (from the pan, valve cover, etc.) and return lines to the holding tank versus pressure lines to the galley? (Different circuit in the latter, I'd think.)
RE: oil deaeration
Moroso did that study a few years ago and found smaller suction lines did work best. (Or is this the same one?)
I ran their dry sump pump with the smaller lines with excellent results.
Bob
showshine@aol.com
