Learning Cosmos
Learning Cosmos
Hi all,
I am looking to learn more about Cosomos. Is there any books out there that you can recommend for this.
Bocephus
Bocephus
RE: Learning Cosmos
Do you have previous FEA experience and if so how much?
Try going to Amazon.com and doing a search. You also get previews to look at.
You might seriously consider taking a class. This might sound expensive, but if you end up with a major goof due to inappropriate analysis it will cost you a WHOLE lot more.
FEA is interesting. It's like making a Lego brick model of the real thing. FEA software will give you a very accurate analysis of your Lego brick model. Problem is if your model does not correctly represent the real thing, neither will the analysis results. It can fool you into a false sense of security and major problems. The issues can be very subtle.
Be naughty - save Santa a trip.
RE: Learning Cosmos
If you don't know what to ask the program to solve for it is very easy to get the "right" answers to the "wrong" questions.
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
RE: Learning Cosmos
with COSMOSWorks" published by Schroff Development Corporation:
http://www.amazon.com/exec/obidos/tg/detail/-/158503158...
Schroff Development Corporation has published "Engineering Analysis with COSMOSWorks" authored by Paul Kurowski. The book is the first of its kind for COSMOS Finite Element Analysis (FEA) software and goes far beyond the scope of a typical software manual. It introduces the reader to the fundamentals of the Finite Element Analysis through lightly but accurately treated theory illustrated with hands-on examples in COSMOSWorks. It describes different modeling techniques in FEA, typical errors, and common modeling problems. It focuses on using the FEA as a design tool and also addresses the topics of FEA implementation and management. The retail price of the book is $59.95 and is available from www.schroff.com and major internet bookstores.
