Calculation for draining a tank
3
I would like to know the calculation for finding the time to drain a static, atmospheric tank of water to a pit, which is also at atmospheric pressure.  Can anyone help?  Please include friction loss and minor losses.
RE: Calculation for draining a tank
Latexman
Thanks for information.  I had looked at the site you gave me, but I was also looking for the actual calculation so that I can check the answers by hand.
ROES,
The FreeCalc linh has a reference  to a Chem. Eng. article giving the basis which should fulfill your needs.
Klem
If you have access to a technical library there are two articles that can be of help:
Chemical Engineering, May 15, 1972 Plant Notebook :"Timing gravity flow from vertical tanks" by E.P. Lynch.
Chemical Engineering, Jan 1989. "Drainig Tanks: How long does it really take ?" by Shoaei and Sommerfeld (with references).
Good luck.
YOU CAN READ  FLUID MECHANICS MA GRAW HILL
IN THAT BOOK DESCRIBE TIME DISCHARGE (DRAINING)
PLEASE SEE THAT BOOK
Formulas fail when vortices form. A vortex may form when:
-The liquid is falling at a rate of more than 1 m/s
-When the outflowing speed is greater than 3 m/s
-When the level is low
-When the drain connection is located away from the tank
 walls in large diameter tanks
-When there are large quantities of gas dissolved in the
 draining liquid
-When the liquid inlet induces rotation
-When the liquids are near their boiling points
-When Coriolis effects may somehow influence the flow
If vortices are a problem, a simple breaker of two baffles at 90 degrees  attached to the inlet, projecting one pipe diameter (D)above and one D  into the inlet has solved the problem for me. The portion above should be about two D wide.
Klem
