Fire Pumps and Overpressure
We have building with several double interlock preaction systems all served by one common riser. This system is boosted by an electric fire pump complete with a pressure relief valve set at 170 psi.
The problem we are having is to do with system overpressure at pump start up. When the pump starts it provides a "bump" on the system raising the system pressure above the check valve to approx. 245 psi. Conversations with relif valve manufacturers indicate that these valves do take a second or two to open.
My question is: How can we contain the initial bump without modifying the pump. My initial thoughts are some type of retard chamber, however I am not familiar with these with such a pressure bump. Any ideas?
RE: Fire Pumps and Overpressure
There are surge suppressers available for this type of application. I don't know of a mfg off hand, but I do have a picture of one and will be glad to send it to you. Let me know.
J. Scott Mitchell
Fire Protection Engineer
And thanks again.
I agree with Scott, the original designer screwed up big time. I recently worked on a project very similar. The only solution other than replacing the pump that I know of is to add a pressure-reducing valve. I personally think it is a poor solution but have seen other people use them. Then in addition to the pressure-reducing valve they installed a couple surge tanks.
Good Luck.
Bryce
SPK Engineering
http://www.spk.fr/index.htm?referrer=securite_incendie
Is this a combined sprinkler and standpipe system? If so how about pressure reducing valves at sprinkler system connections?
I heard they sometimes solve this problem wit a jaw-way valve (don't know if I spell it correctly) . This is a valve with a quick response time, to relief the pressure in the system.
This bump could also be the result of water hammering. Check literature how to prevent this from hapening.
bye
