dwg to pdf - image will not print
A tiff is attached to acad2002 DWG. We are printing to Adobe pdf 6.0 Pro. The tiff appears in the full print preview but does not show on the PDF itself. (the autocad entities print fine.)
Has anyone come across this? Any suggestions?
Thanks in advance.
Thanks in advance.
RE: dwg to pdf - image will not print
mvg
HMO
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
