SLC 5/04 and TI-565 communication
Hi Folks,
I have an older TI-565 PLC and a newer Allen-Bradley Slc 5/04, that are physically located about 200 yards apart.
I need to be able to pass a few words from one machine to another. One possible solution would be to use Modbus as the
go between. I know AB has a PRO-Soft card for modbus and Siemens has a modbus card for the 565. My question is considering the distance, will I need some type of repeater/signal booster for this setup. If anyone has experience with this type of setup, or something similar. Please share your thoughts.
Ken Moore
NSCC-Wdrf Plant
RE: SLC 5/04 and TI-565 communication
Thats a good solution if you dont want to mess around with protocols.  Its been a few years but....
I used a TI Basic module with a RS422 converter  to the serial port of the SLC504.  I had to play around with pinouts and built my own cables which took longer than I wanted.   I ran it at 9600baud.
Pretty slow, but it worked.
How much data do you really need to passs between the units?  If its not too much, you coud do it iwth digital I/O quite easily!
AB has a "black box" that translates ti to ab. it is around $500 U.S. You would have to config both for 422. i have used this box with ti545 to a pv1000 but it was with rs232.
Can you give me any info on this "black box"?
Sounds like the cheapest option.
thanks,
Ken
prosoft makes this "black box" converter (it's actually white)for AB. check out their web site. if you do not find what your looking for, reply back and i will look up the info/part# that i used.
good luck
rubha
