Scaling viewports in paperspace
Have a drawing with one viewport in paperspace that i want scaled at 1:75.I have been right clicking on viewport & using properties to enter a custom decimal number of 0.015 which i thought may be 1=75 as 1:50=0.02 & 1:100=0.01 but when i print off lines are slightly to long by about approx 200mm when i run a scale rule over. Is it just that i am entering in wrong decimal factor & if so what is 1=75?
If not, any ideas?
Thanks for looking & a very merry christmas & happy new year!
RE: Scaling viewports in paperspace
cadmonkey,
I think your scale factor is wrong. 1:75 = 0.013.  0.015 = 1:66.  Not much of a difference but enough to through your scale out.
Thanks for the swift reply!!
What is the formula then for working this out just for future use. I have applied this but need to check with a scale rule, I setup a blank drawing with the limits setup at A1 paper size x 75 a drew a line 1mt long to make my own scale rule a printed off but the line on my drawing with the 1:75 viewport is still 50mm short when printed. I'll get a proper scale rule over christmas just to be 100% but i hope that this will solve problem, setting scale in viewport to 1:50 or 1:100 & printing works perfectly so I thought that it must be the decimal factor.
Thanks again & Merry Christmas!!
cadmonkey1,
Your discrepency has gone from 200mm to 50mm so you're getting there.  In the viewports toolbar, you'll notice that the scale is given to six decimal places.  This too can make a difference.  Try 0.013333 and measure again.
To arrive at a scale factor, divide 1 by whatever scale you want i.e. 1/75 = 0.013333, 1/50 = 0.02, 1/100 = 0.01, 1:2 = 0.5 etc.,
Let me know your result.
Merry Xmas
In the viewport properties, you can put in 1/75 and it will do the math.  You can also select from standard scales in the box above.  R2004  Note that your printer may scale objets also...
IFR,
1:75 is not one of the standard scales in the box.  Not in 2002 at least.
I would make sure that you are plotiing 1:1 or the correct scale factor. make sure you are not scaling to fit.
cadmonkey1,
Sorry to use your post reach someone else. Maybe IFRs knows the answer to my post about the alert boxes.
Haggis-you are a CAD GOD!!!!!
Works fine now when scale inserted to 6 decimal places.
Top Man-Have yourself a great christmas.
Thanks to everyone else for their suggestions.
To answer your question of what is the formula to convert 1:75 to a decimal . . .
1:75 = 1/75.  To convert this, or any fraction to decimal, simply divide the bottom number into the top number.  Or, in this case,  75 into 1.0 = 0.013.
Cheers .. . Rocky
Maybe I'm missing something in the question but can't you just zoom to scale in the viewport? Like : View/Zoom/Scale/
1/75xp for one seventy fifth of paperspace scale or to whatever scale you want. For instance: 1/8" per foot is 1/96xp calculated as 1"/(8*12").
