Process Probe
Process Probe
I'm looking for a retractable process probe that can be inserted and removed from a process stream in situ.
The process gas is @100C and 1000 psi so the extraction method must keep the gas isolated from the system that the probe is removed from.
The probe would vbwe a nomial 1/4"-3/8" OD and be flange mountable if possible. The real key is finding one, we can desaing a mounting sytem for it. Thanks.
RE: Process Probe
RE: Process Probe
Welker Engineering
YZ Industries, Inc.
