Can I use 'Countif' to calculate results of IF statements??
I have a number of cells that I've used an IF statement on to determine a certain result.
I've simply used IF text entries in a range of cells to determine if values are - "low", "medium", "high".
What I'd like to do is count the number of times any of these labels are used within a range of cells.
100     low
500     high
900     high
result: 2  (high)
When I use 'countif', I don't get a result.
Any suggestions please??
RE: Can I use 'Countif' to calculate results of IF statements??
The line
=COUNTIF(C2:C4,"high")
works for me (the range C2:C4 being the cells in which the IF formula places "high", "medium" or "low").
