Looking for 180 rpm synchronous generator or motor.
I'm trying to find a synchronous generator or motor in the 550-750 kw range or a motor in the 700-1000 hp range.  (voltage 4160) I need a 180 rpm unit 40 poles. Will consider a 200 rpm unit if that is available.
I've looked in the surplus record and have call around. So far have not had much luck. Does anyone know of a unit that's retired in place or something that is sitting around gathering dust.
A new machine is not an option.
kruger1@worldpth.net
RE: Looking for 180 rpm synchronous generator or motor.
Suggestion: Visit
http://www.thomasregister.com
and type Generators: Synchronous under Product or Service, which will return 25 companies to approach to
