History Palette
History Palette
How to remove the unwanted icons/links from the history palette of UGNX Resource Bar.?
RE: History Palette
UGNX2=Preferences --> Resource Bar... Clear History button
-Derek
DL Engineering Services
specializing in CAD Design Consultation Services
www.dl-engineering.com
RE: History Palette
I mean only part of the history.I wanted to remove only certain unwanted icons,not the whole history.
Any suggestions please?
RE: History Palette
I done some research and finally found the way to remove broken links,unwanted lists in the history palette.
(These are broken links shown whenever a prt file is deleted )
RE: History Palette
So how did you remove the broken links?
thanks
RE: History Palette
The History palette is located somewhere in your Hard drive,
most probably in C:\Documents and Settings\"USER"\Local Settings\Application Data\Unigraphics Solutions\UG\
Right mouse Click on history and open with Notepad or any text editor.
Locate the name of the link which is broken and to be deleted.
Delete between <PaletteEntry id=" ">- - - - </PaletteEntry>
just save.
Open UG and check your history.
Good luck
(make sure you keep a backup of the file before you modify)
