Double Shear Bolted Connection
When splicing two beam ends together with one splice plate each side of web, should one consider the web thicknesses of the beams when employing the allowable double shear values in AISC Table I-D? Is there a minimum web thickness for double shear?
Thank you!
Thank you!
RE: Double Shear Bolted Connection
