ASSEMBLY CLONING
ASSEMBLY CLONING
ASSEMBLY CLONING
Hi all,
I cloned an assembly in another directory and when I want to open that cloned assembly I get an error:
"Failed to find file using current search options, part left unloaded".
Is there a setting in File-Options-Load Options which could fix the problem?
alf
RE: ASSEMBLY CLONING
Check out this thread: Thread561-80335
I think it will answer your question or at least get you pointed in the right direction.
