Pressure drop values given in the STHE
Pressure drop values given in the STHE data sheets are inclusive of nozzle pressure drops or exclusive of nozzle pressure drops.
RE: Pressure drop values given in the STHE
Good luck,
Latexman
STHE - shell and tube heat exchanger.
I don't believe you have to worry about those details because the accuracy of the predicted shell side pressure drop is not that good. I have never found anybody or a computer program - HTRI included - that could predict shell side pressure drops with enough accuracy such that the nozzle losses could make a difference.
Shell side losses are very, very difficult to predict and the only exception that I have ever experienced is the ability of captive technology used by specialist companies (such as Graham condensers) in predicting (& guaranteeing!) the very small pressure drops in their vacuum condensers. But these devices are very special and arcane in design. These special devices are very different from a conventional shell & tube design and their design is a well-kept secret. But even they have a conservative calculation and carry contingencies in the calculated design.
If you have a problem with nozzle losses in a S&T exchanger, I believe the best approach is to use a conservative design; i.e., use larger nozzles than calculated or eliminate impingement plates and use other techniques such as distribution shrouds - such as the old Braun heat exchangers used to use.
Hope this helps you out.
Art Montemayor
Spring, TX
Thanks a lot.
Also on the tube side of HE, pressure losses include inlet and outlet nozzles, as for the inlet and outlet of tubes, both generally taken for liquids to be 1 and 0.5 velocity heads, for sudden contractions and sudden expansions, respectively, (Perry et al. Chemical Engineers' Handbook).
