fixing materials for testing
I want to setup a small test environment.
I need equipment to fix some parts to be tested
I need eg a bottom plate with many holes in it, round bars to put into these holes where i can fix some thing onto.
All I found is some equipment for measuring machines, but this stuff is way to expensive and to accurate for what I need.
Anyone has any experience with this equipment?
RE: fixing materials for testing
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
The other options are a machine base or a dial plate. You can get either blank or they will drill and taps holes to your design.
Here is one that we used a lot for machine bases and dial plates.
http://www.americangrinding.com
