Problems in the simulation of a tensile test
i have been working with Abaqus since two weeks in the University. I
have to simulate a tensile test with steel. Now i have serveral
problems and i can´t find a solution in the Documentation.
1.) How can i get a stress / strain curve for a defined region of my
tension bar? Already tried to change the histroy output requests in the
"step" module. I selected the outout variables stress/strain for the
domain whole model. But this message appears:
"Node-based and element-based history outout variables.........."
So i created a set. But which vertices or edges should a select? I´m
only able to select edges an vertices, which i created in the part
module. I can´t get the exact region i want? What can i do here?
After trying everthing i don´t get variables for stress/strain in the
History output in the Visualization module!
2.) In the load module: how can i get my boundary (encastre) to be on
the whole area where my clamping on the tension bar is. I can choose
the vertices and the edges but not a part of the area?
3.) In the Material options in the menu plastic: the data do i need the
true or the engineering stress/strain?
Hope you understand my "english" and help me!
Thanks alot and merry Christmas and a happy new year
Jan
Jan
RE: Problems in the simulation of a tensile test
As far as I know:
1. TRUE stress/strain is required for material in Abaqus
2. You can't creat stress/strain curves directly..u may get stress/time curve at certain element or node as well as strain/time curve..then you could combine them to obtain stress/strain curve
3. If you are using CAE, your tensile specimen can be divided into three areas: one at the middel and two at the boundaries.
Good luck
