Load factor
Load factor
Load factor
What would be industry load factor for a stationary machine compaired to a portable machine?  For example if a machine was designed to support 1000 lbs in a stationary environment,  what would be the rated load in a portable environment with highway and off-road transportation
RE: Load factor
I think structural contraptions are developed with one of such goals in mind. The structural requirements of  structures of fixed position, mainly buildings, are reasonably well described in the pertaining codes. I think on the contrary that the characteristics of machines are more a function of the required performance, so it is difficult to establish a general relationship like the one you are asking for. For example, impact forces of the bouncing vehicles on a bridge do not need to be comparatively bigger than the ones suffered by some component in the vehicle itself, since the forces can be further than such component lessened either inertially or by dampening of the forces with derivation towards other parts in the vehicle.
If you can describe the exact case more completely maybe someone can draw from his experience to share.
