Colour printing a SW Drawing not assembly or part
Hi is it possible to print a colour SW Drawing? So far I can print colour assembly drawings but not template drawings
yvonne
yvonne
RE: Colour printing a SW Drawing not assembly or part
http://www.dynebits.com
called layout.swp that will do all of this for you.
Ken
If so, you can assign components and lines to layers and assign the layers a colour (and linetype) within the layer dialog box.
To assign a component to a layer, either right click on it in the Feature Manager (under a dwg view) and select Component Line Font, or click on the part in a view and select a layer to place it on.
Other lines (projected geometry or normal sketch lines, text, dims etc) may be assigned colours using either the line type tools, or by assigning them to layers.
Make sure that the colour display mode button is toggled correctly.
Hope I'm barking up the right tree here...
Chris
the web site that u 've given is not correct. spelling mistake.
this is correct website name.
http://www.dynabits.com/
very nice web site.
they 've given some free macro and api tips also.
its really very nice... they 've given lot of links also..
thanks kenbolen...
regards,
murugan.S
Design Engineer,
GlobalSoft Pvt Ltd,
New Delhi, INDIA,
murugan_subham@yahoo.com
