Chrome Vanadium Steel?
I am looking at manufacturing a special 1/2 drive socket - the type that Gedore, Snap-on etc make. What would be the closest material available in bar stock that would represent the type of material that is used for these items?
I have only come up with EN40C (897M39) as a possibility. (It has quite a wide tolerance band on the vanadium content 0.1/1.3%)
The other question is why Chrome Vanadium? - Would 807M40 do the same job?
I know this is quite an open-ended question, but I would be interested to hear any views.
Many thanks
Paul
RE: Chrome Vanadium Steel?
Vanadium is considered a "grain refiner", which means that it tends to keep the grain size small.  Small grains are desired for just about all properties except high-temp. creep strength and hardenability (depth of hardening).  Highly stressed parts such as springs are frequently made from Cr V alloys.
The alloy 6150 comes to mind.
