ACad 2000 & Windows XP problem
Hey there,
I just got a new computer at work, with Windows XP Professional loaded. I installed Mechanical Desktop 5, and I have a problem.
Whenever I open or save a drawing in AutoCad, the dialog box comes up with all the files in "icon" view. In order to be able to navigate through and find the file I want, I hav eto change the view to "list", which is what I prefer. Prior to this, I ran Windows 2000 Pro, and the view was always "list".
I have configured my folder options in Windows to be "list", as that is what I prefer. All other windows applications and other software list the files the way I prefer. All except AutoCAD.
Does anyone know of a way to make AutoCAD default to a "list" format rather than the current "icon"? Perhaps a variable command somewhere that I am not aware of? Of is this just a glitch between AC2000 and WinXP?
We are upgrading (finally) to AC2004 within a month, so hopefully this will not be an issue then. In the meantime, if anyone has any ideas or suggestions, I would appreciate it.
Thank You.
Thank You.
RE: ACad 2000 & Windows XP problem
However, in your Acad "open" dialog box, there should be a dropdown at the upper right that says "view" and you can set it in there to list, details, etc.
The AutoCad web site siad this a design feature :) and cannot be changed to default to list.
Hopefully you already upgraded because today was the last day to upgrade ACAD 2000-based products (ACAD 2000 is being "retired").
From Autodesk Website:
"Autodesk will discontinue service and support for AutoCAD 2000, the full line of AutoCAD 2000-based products, and Autodesk Inventor 4 on January 15, 2004."
Flores
I would recomend strongly against Xp Home.
Perhaps I just am lucky?
And then installing my applications. I have never had a problem with AutoCAD (or any other applications) File dialog boxes by doing it this way rather than trying to change them after the fact.
As stated below, making the change in any of AutoCAD's File dialog boxes are not retained... so I am assuming they are set and remain as ther were set up when installed.
BTW I highly recommend both AutoCAD 2004 running on XP Pro.
- Tracy
View setting in Select File dialog box is not retained
Published date: 2001-12-06
Applies to:
AutoCAD® 2002
AutoCAD® 2000i
AutoCAD® 2000
AutoCAD LT® 2002
AutoCAD LT® 2000i
AutoCAD LT® 2000
Issue
On the File menu, you click Open. In the Select File dialog box in the Views drop-down list, the view type always reverts to List in a new session of AutoCAD, even after you changed the view type to Details
Solution
This is as designed; there is no way to retain the setting.
