how to cut-extrude feature around a path ?
Hi happy solidworkers,
I've been trying to Cut-extrude a snapon lip feature in the inside of a plastic square container that has filleted corners.
So, I defined my profile in a sketch and then selected the path sketch. The problem is that the profile is performed only in one side of the container. Do you know how to make the cut-extrude feature go around the border of my square container, including the filleted corners?
Thanks in advance,
Vanleurth
Thanks in advance,
Vanleurth
RE: how to cut-extrude feature around a path ?
My sketched path goes around the corner including the fillet and it is a close rectangle.
I tried to select different options, though all, blunt, etc. but it didn't work. Then, there is an option down below the feature manager of sweep where I could include profiles. I tried to get my sketch entered there but no luck.
Perhaps, this is a begineers question but I don't know how to do this.
Let me know if you might have another insight on this problem.
Thanks again
read
Thread559-65247
in this forum
Thanks again ;)
V.
