Phosphoric Acid Corrosion
Which metals are suitable in a solution of 10% phosphoric acid, 50% naphthenic distillate+mineral oil, 10% glycol, 5% water balance neutral?
RE: Phosphoric Acid Corrosion
I understand that the temperature of phosphoric acid is also the subject to be considered. Stainless steel 316 may be suitable for "cold" but not for "hot" of 10% phosphoric acid.
PAN
