crash due to High quality in drawing
Hi
can any one tell whts the reason behind this scenario.
Ive have a top level assembly with two sub assembly say A.sldasm & B.sldasm. Then I created a new top2 assembly with A.sldasm as my component.Then i created a drawing views from the top1.sldasm with high quality .Then i went back to my Top.sldasm & i made my A.sldasm as lightweight & directly switched back to my drawing doc . Now my SW application crashed.
Senthil Kumar.E (B.E Mechanical)
senthile@geometricsoftware.com
RE: crash due to High quality in drawing
It would help us to know what hardware, drivers and SW version and SP you are running.
Most crashes can be attributed to sub-standard components (older video cards) and outdated hardware drivers.
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Slee123,
I just re-read your other post which details your computer components.
Have you tried working withthis assembly on another computer?  Does it also crash?
Ray Reynolds
HI madmango
ive even tried this on high configuration machine which has zeon processor & 1 GB ram & 128MB graphics card . it even crashed on that Machine too.
Make sure you have done the basic computer clean up. Clean out the temp folder, defrag the HDD, turn off your AV when running the file. You can try turning off all add-ins to make sure it's not conflicting with the file.
Did have the AV off when you installed?
Try sending the file to your VAR and see if he crashes. If so then the file maybe corrupt. It could be a part of the assembly. The best way to test this is to open all the parts and sub-assemblies to make sure one of them are not corrupted. If a part or sub-assembly is corrupted it will cause the main assembly to crash. Not to say the main assembly isn't corrupted, it could be. Once you find the file he (the VAR) can send that file to SW, to get fixed... Of course that depends on the type of corruption in the file.
IHTH! (I Hope That Helps)
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
I agree 100% with Scott.  It's time you went and beat down your VAR's door with this one.  That's what YOU are paying THEM support for................!
Be naughty - save Santa a trip.
