Express Tools "Command Line Only" tools
To a previous question smcadman wrote this reply:
  < The express tool you're looking for is "bcount", one of the express tools that are "command line only".
  <Flores
Are there any other "command line only" Express Tools that we should be aware of?
RE: Express Tools "Command Line Only" tools
See Express Tools Help.  TFRAMES is the only one I've used (to toggle wipout frames), there's also SSX, EXPRESSTOOLS, EXPRESSMENU, others.
the version ETV1-9 (AC2000 - 2002) is different to ET 2004.
One command is "lsp" (2004). Displays a list of AutoLISP commands available at the command prompt.
There You can see a lot of "command line only"...
Lothar
Thanks CarlB and Exxit for the responses.
The best part of Express Tools help is the Web Links item.  There I was able to find quite a bit of information.
Lsp also works with AC2000i.  It listed bcount and others.
