2004 Materials Libraries
We've been using Material, Finish and Heat Treat as Custom Properties and actually have start parts for common materials with these Custom Properties defined. The density and color is also defined in our start parts. Over time, we've added more materials and are finding it cumbersome to sift thru all the Material "start parts". Also, it takes some time to change the Material Custom Property, density and color of the part if the material is to change on the fly.
With the new Material Manager in 2004, we would like to create our own smaller library instead of the comprehensive list of SolidWorks default materials. We've done this already. Now we've linked our Custom Property called Material to this library but would like to add Finish and Heat Treat. The Material portion works very slick. Simply edit the Materials in the part and the Custom Property changes and the BOM is updated.
If possible, we'd have only one start part in place of many and we'd have the flexibility to change the material on the fly. Any help would be greatly appreciated.
Thanks!
Thanks!
RE: 2004 Materials Libraries
Ross
