PCB Properties
PCB Properties
Does anyone know where to find or what the PCB thermal properties are? I need:
Conductivity
Density
Specific Heat
Also has anyone used QFin for thermal designs?
Conductivity
Density
Specific Heat
RE: PCB Properties
RE: PCB Properties
printed circuit board
You need to specify the material of the PCB.
FR-4, etc. There are dozens of materials:
http://www.nemaplasticfabricators.com/Assets/NEMAPlasti...
TTFN
RE: PCB Properties
They are no longer (since 1977) manufactured in the US, and their use and disposal is totally regulated by the EPA (incineration at temperatures >1100oC, long residence times, specially designed incinerators).
Former uses were wide-ranging and based on PCBs unique combination of properties: fire resistance, thermal and oxidative stability, electrical characteristics (high dielectric constants, high volume resistivities and dielectric strength), solvency in most organic solvents (but not in water, glycerol and glycols), inertness, and liquid range.
The largest use was in electrical equipment such as transformers and capacitors.
If PCBs properties are of interest I assume Monsanto could be a good source of information.
RE: PCB Properties
http://www.nvf.com/phenolite/datasheets/eg873.htm
I used FR-4..
