adding custom structural member
I work for a lighting fixture design company, and I'm trying to add a track lighting extrusion to my toolbox. It would work just like the steel beams that come in the standard toolbox. The problem is i cant link a custom property called length to the dimension associated with the extrusion. Tech support said there's no way to do it inside solidworks, so I'm trying to do it through the API. Has anyone encountered this problem before? We really need this to work, to avoid creating 1000 different configurations for each 1/8 inch increment possible.
Peter Jelliffe
Peter Jelliffe
RE: adding custom structural member
I'm not sure if this is what you are trying to achieve but thought I would throw it out there.
