UNIT OF JOINT MASSES in SAP 2000
What is the unit of joint masses that are required to be given for a dynamic analysis. Is it different when the chosen unit is KN-M or N-M.
If a joint rection is 100 KN and chosen unit is KN-M , what would be the value of that joint mass ?
RE: UNIT OF JOINT MASSES in SAP 2000
The rule for the units of mass is you take your units of weight, and divide by the acceleration due to gravity in the units of length you are using...sometimes this doesn't come out to a normal unit (for instance if you use kips and inches: (kip.s^2/in)).
