hedgehog packing in scrubber
I am looking at the re-use of an existing scrubber which uses 'hedgehog' packing.  I don't have any data on the packing characteristics.  Does anyone have any data on this type of packing or any idea where to find any?
RE: hedgehog packing in scrubber
You got me on this one. Can you come back with a little more description as I have been around a long time and never heard that term.
The only thing that I've ever seen that could remotely resemble a hedgehog is a plastic variation on the Berl or Intalox Saddle. Could it be a Telleratte?
A few years ago we had the same problem: considered they were equivalent to 2" Pall Rings (for Kga) and the scrubber has been running well ever since.
Ed
Ed Clymer
Resinfab & Associates
England
Looking at the amount of surface area it looks like they  should perform better than a pall ring in clean system, if you can find one.
I would check with Clemson and see if they have some data either the manufacturer or from the unit operations lab.
