spot welding cooling system
I want to know more about design & type of cooling systems & its calculating methods usually used in automotive manufacture body shops
RE: spot welding cooling system
The first is the cooling for the weld controler. The other is the cooling for weld guns and transformers. your equipment supplier should assist you to decide the requirements of the cooling system. Mostly you need to calculate the GPM requirements. Be careful if the welding is MFDC, the GPM requirement is much higher
